I bought a 1987 toyota pickup a bit ago and have been having brake issues, i've replaced the master cylinder, passenger rear wheel cylinder, and the rear brake line but still having braking issues after bleeding the brakes and everything, could it be the brake booster (brake servo)? And if so...
Hi,
On my truck: denso part 88650-89113. Saw one for sale on ebay but they indicate same part number as the 1989 pickups...Toyota dealer says they show a different part number for amplifier than the one in my truck for $280 But that my part no is 1989 (for $50+) I looked up 89 part and it’s...
Hey guys first time using a forum. I've been working on a 1985 basket case that was brought to me a couple of weeks ago.
Have completed complete reconstruction of front end, drive shaft, E-brake cable, throttle cable, bearings, brakes (calipers, rotors, lines, wheel Cylinders, master cylinder...
I just got a 88 pickup v6 with a 5 speed. Im not sure if I need to bleed air from my clutch line or what. If I start my truck. I push the clutch in and it won’t go I to gear. Any gear. It’s like my clutch isn’t engaging. But sometimes it works fine. Not sure.
