1 - 20 of 28 Posts
toyota camry
my parking and interior lights are out .... maybe it burned out, fuse, or i need new bulbs? help!
Check the fuse box under the steering wheel.
Pull out the tray and on the back, it should have a sticker with all the fuses and what they are for.
It's most likely a blown fuse (15 amp) most likely coz that happened to me before. check the interior its either a 15 amp or a 20 amp fuse.
toyota camry
Discussion Starter · #5 ·
its just the interior its the out side lights too when you dirve at night the tails and the front two corners dont work wheres the fuse for that at?
The DRL relay, the master switch in the flasher harm, light relay ... but after that i dont know
Good luck!!
David
toyota camry
Discussion Starter · #9 ·
i found the burned out fuse i put two 15 fuse in and less than 3 seconds it blew it so do i need a higher fuse or something is wrong with the wireing?
Highlander
Did you put in any aftermarket bulbs, relays, etc. before the problems arose?
toyota camry
Discussion Starter · #11 ·
no aftermarket bulbs except for some indiglows which those are pluged into another fuse had them about a year or so, i put in 2 -15amp fuse they just burned out in 3 seconds.
toyota camry
Discussion Starter · #13 ·
the car was shut off and i put a new fuse in then turn on parking lights and about 3 seconds again it blew. blew about 5 fuses already so i think its the wireing.
Highlander
Why do you have the Indiglos powered off another fuse? You're using fuse taps? Which fuse are you tapping off of?
toyota camry
Discussion Starter · #16 ·
the fuse tap to the indiglow is another fuse dont know which one but dont really mind that the thing is that i really need to fix it because i need to drive at night and have no parking lights.
So the fuse didn't blow when you opened the door (activating the dome light.) That should mean the short is in the park lights. I would have a look at the sockets first. Only one part should have cont. with ground. If they both do, that is where the short is.
Highlander
Disconnect the indiglo first and replace the fuses again to see if they pop. You should never tap into a fuse, or any other, to power something like indiglo gauges since they require a good amount of current.
toyota camry
Discussion Starter · #19 ·
there is nothing wrong with the indiglow and the fuse that i taped it on, the other fuse the parking light fuse/ interior the stop fuse thats the fuse that blows every time i put a new one in
1 - 20 of 28 Posts
