1 - 9 of 9 Posts
· Idon't brag I mostlyboast
MTA MetroCard
What do you think is wrong under the hood if 5SFE rpms go up when you turn on the high beams?
I kid you not. It really happens
· 3s-gte in a Camry?!?
'89 Camry Alltrac
need more details...
when you are idling?
how much to the rpms go up?
if its when you are idling and its only like 100rpm or so, its normal...
MTA MetroCard
Discussion Starter · #6 ·
this is at full stop. RPM goes from 750 up to sometimes over 1000.
Little extra for ya, ever since I had a dealer in Stockton replace my distributor coil in January, if I sit long enough (15 sec), RPM goes down to near 500-rough idle then goes back up. Before that repair, the car would sputter. I thought it was due to the possibility the dealer didn't replace the coil at TDC, but it goes away when the car's in neutral.
1 - 9 of 9 Posts
