1 - 5 of 5 Posts
Please help!! Ok. I am getting codes p01300 and p01310. I changed the crank position sensor that is what I was told to do to fix it. Still cranks but wont start. Has anyone had this problem?
Might help to post in the 99 forum instead of the 2005+
Super Moderator
2006 Corolla XRS
Moved thread to the 1st gen Tacoma forum.
Not sure who told you that, but a quick search shows both of those codes relating to the ignition system. Should be a pretty easy fix, you just gotta check the ignition system.
If you google the codes it will tell you what to look for.
It might be a fuse there should be a white fuse that is bolted into your fuse box. You have to buy a new fuse for your Tacoma. It costs about $4.00 to get a new one. Your truck is the same year make and model as mine. Had the same problem it was "The Alternator Fuse". The Fuse had melted and blew up. It's under a different name try looking it up or taking a picture of it then going to O-Rileys or Atuozone or any place like that.
1 - 5 of 5 Posts
