I hope it's that and not the head gasket or piston rings. I just replaced the NGK iridium IX plugs with Denso twin ground platinums. I'll check again in 2 weeks and if the leak continues I will replace the spark plug tube seals.Then bad spark plug tube seals? On the 5SFE should be a 30 minute project to take the valve cover off and replace all the seals in there.
