Update:
Putting the old dis cap back on must have been just a coincidence...Cos today I did it again and the problem remains!
Idle is sitting on 1800rpm...steady as a rock!
I have checked the timing and it is NOT the cause. I did a static time (which I must say did not need any adjustment..looked pretty well perfect!) and then went to a friendly mechanic and "borrowed" a timing light - Thank you Bill - which confirmed the timing is right...So you can static time a 3SFE !!
I am now wondering about the idle control valve. As I stated in an other thread, the ICV has been replaced. But I did check the new one anyway and it seems to be OK.
Any suggestions??
Thanks
Any suggestions??
Thanks
