1 - 3 of 3 Posts
I have a 2016 Highlander and recently the battery died. After jumping my car, the front section of the a/c and heat doesnt work, to include defroster. However in the rear of the vehicle both heat and a/c works as usual.
2016 Highlander XLE
Try disconnecting the negative terminal, wait 5 minutes, then reconnect. This may result in a reset. If that doesn't work, check your fuses. may have blown one. Check for the correct fuse in the owner's manual.
1 - 3 of 3 Posts
