Highlander AWD Rear steering knuckle bushings
15767 Views 7 Replies 6 Participants Last post by  Bonnie44!
Has anyone found replacement bushings for the Rear steering knuckle on 2004-2007 Highlanders with AWD? No one sells them, even Toyota. They want you to buy the complete steering knuckle with the 3 bushings already installed for around $400. There must be a replacement available if we knew the exact size of the bushing(s). Thanks.
1 - 8 of 8 Posts
See if this link works:
https://www.rockauto.com/en/catalog....3l+v6,1431009,steering,knuckle+bushing,15419
Let me see if I can find you some decent links to the ones I ordered off Amazon.I will recommend just buys the arms which will have the frame side bushings in them already if you need them or if you even have a doubt about them. The arms are under $20 a piece which helps.
OK the list below should help get you in the right direction. Remember this is for the AWD not FWD. If a quantity is listed that is how many you need to replace them on both sides. Some parts are the same but used in more than one place. The reason I used the Dorman arms in this list was the no one single vendor at the time had everything in stock and I could get them to my house within the time I had available. Odds are you will need new bolts, I used grade 10 metric stuff I matched up at the hardware store, I would have saved a ton of time had I cut mine off right away and had access to a set of torches.
2X - Dorman 522-414 Control Arm (Rear Lower Forward) - https://www.amazon.com/gp/product/B019AL9WZI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
2X - Dorman 521-911 Trailing Arm - https://www.amazon.com/gp/product/B00FEQT402/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
FEBEST 0125-1ACU35 Rear Left Track Control Arm - https://www.amazon.com/FEBEST-0125-1ACU35-Rear-Track-Control/dp/B00HAPARRE/ref=sr_1_1?s=automotive&ie=UTF8&qid=1503145966&sr=1-1&keywords=0125-1ACU35
FEBEST 0125-2ACU35 Rear Right Track Control Arm - https://www.amazon.com/FEBEST-0125-2ACU35-Right-Track-Control/dp/B00HAPB930/ref=sr_1_1?s=automotive&ie=UTF8&qid=1503145940&sr=1-1&keywords=0125-2ACU35
2X - FEBEST TAB-300 Rear Arm Bushing Assembly - https://www.amazon.com/gp/product/B00R97TL1Q/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
4X - FEBEST TAB-166Z Rear Arm Bushing Assembly - https://www.amazon.com/gp/product/B00R97RGD6/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Picture from FEBEST to help show what is what:
If I can be of anymore help send me a PM and I will get the email notification quicker than coming back to read the thread:). It was a tough job but I did it and saved a ton of money. In my case I only needed to replace 2 out of 3 arms on each side but all 3 bushings in the knuckle. Everyone calls it a knuckle as do it, I think in my research Toyota calls it a axle carrier sub assembly.
Again if anyone is tackling this on a first gen and its AWD I would be glad to answer any questions I had, I was frustrated all to often due to lack of documentation out there since Toyota would rather not have to worry about the individual components so they only list the knuckle in the literature I came across.
Reactions: 2
I posted a complete post about that.
http://www.toyotanation.com/forum/8...9-lower-rear-suspensions-bushing-knuckle.html
And I suggest to you that DON'T install this febest made in crap china parts..............................
That was my 4th time to replace the same bushing and 2 on warranty ......................
I found an other alternative parts that replace this bushing.
This is siberian bushing on ebay, I stand for my parts around half october and I give us to you some developpements about that new concept bushing! the parts replace for tab-166z and tab-300.
Hre they are :
http://www.ebay.ca/itm/Polyurethane...Kluger-Avalon-Highlander-Carina-/161863616106
http://www.ebay.ca/itm/PU-Bush-Rr-S...00H-Kluger-L-V-Kluger-HV-Harrier/161863618155
Welcome
Th.is looks interesting.
https://www.clublexus.com/forums/rx...with-new-oem-bushings-spherical-bearings.html
solve
I spend 5 hour of my life but I got result!:grin:
Remove Knuckle
https://photos.app.goo.gl/LhUzVsLKDOz0qa0d2
Don't [email protected]## with the speed sensor! I just tried to pry it and it crack :crying:
https://photos.app.goo.gl/NG5oICTEsNxoaF5K2
https://photos.app.goo.gl/fLFw6pdsD6CzCDuj2
Remove old scrap bushing. Personnally I was bored to change 1 bushing one by one. So, I replace all tree. And I don't try to remove the bolt, just cut it!:wink:
https://photos.app.goo.gl/8WDULvMyTqqCLuxz2
https://photos.app.goo.gl/ZWJlbqdG2KmDRAjJ2
https://photos.app.goo.gl/My0aws4EwrutfWxl2
https://photos.app.goo.gl/kAHWfNoV6StTCtYf2
Clean your bores particullary the lower one
https://photos.app.goo.gl/F6KJ0IdECVkh2i9C3
https://photos.app.goo.gl/Ebq3vU89UPnFSvTr2
And the job done! That's so cute haha!!!!!:smile:
https://photos.app.goo.gl/prFyo0ug3mv1wmSd2
After the job the vehicule no need complete alignement, maybe chance go with me
FEBEST 0125-1ACU35 Rear Left Track Control Arm - https://www.amazon.com/FEBEST-0125-...F8&qid=1503145966&sr=1-1&keywords=0125-1ACU35
FEBEST 0125-2ACU35 Rear Right Track Control Arm - Amazon.com: Rear Right Track Control Rod Febest 0125-2ACU35 Oem 48730-48120 : Automotive
Hi there I need suspension knuckle bushings for rear 2007 Toyota Highlander and nobody knows anything or what they are actually called…. Very frustrating to say the least could you help please!
1 - 8 of 8 Posts
