Drill press only pulley wrench, from McMaster Carr:
98023A044 $12.12 5/pk
Zinc & Yellow Grade 8 Steel Flat Washer
~48mm ID
~86mm OD,
~4.8mm Thick
(I used all 5 = 23mm ht)
9516K273 $15.35
O1 Tool Steel Tight-Tolerance Flat Stock
1/4" Thick x 3/4" Width, 18” length
(drill through slowly with much cooling oil, as with washers)
Only 1 of 5 (bottom) washer drilled 5mm and tapped
2958A83 $2.10
Metric Black Oxide HSS Jobbers' Drill Bit
5.0mm, 86mm Oal, 42mm Drill Depth, 118 Deg Point
(for 6mm bolt tapped holes)
8305A17 $6.75
Metric High-Speed Steel Hand Tap Taper,
6 X 1mm, D5 Pitch Dia, 4 Flute
2896A25 $2.30
Black Oxide HSS Short-Length Drill Bit
1/4", 2-1/2" L O'all, 1" Drill D, 135 Deg Point
(for 6 x 6mm bolt through holes (4 washers) and 2 x 6mm bolt through holes (1 washer), drill all washers together with 4 bolts securely holding)
Assorted 6mm x 1.0mm cap screws
2 x 35mm length to affix handle to spacer and washer stack
2 x 25mm length to secure other side of washer stack
2 x 40mm to attach tool to pulley (72mm CTC)
total cost of materials $27.47 + shipping
plus fasteners and specific drills and taps about $45
5washers drilled with 4 x 1/4" through holes and used as guide for 4 x 5mm through holes in bottom washer, 5mm holes then tapped to 6mm x 1mm, tap with care to make holes perpendicular to thin washer!
stack secured and then 4 x 1/4" through holes at 72mm CTC drilled slowly through all 4 washers with much oil, handle drilled with 1/4" through holes and all tightened down (6mm pins could be added by drilling from other side)
added bar spacer (14"= 6.35mm) cut from handle to get clearance (see below post)
6mm x 1mm fastener pairs lengths (from top to bottom) 35mm/40mm/30mm
(40mm bolt to pulley gives 17mm thread; plenty!)
2 x 6mm dowel pins (if needed) could be added with 24mm x 6mm pull out dowel pins (97355A302) at $1.31 each
with 6mm hole through 2 bottom washers, and 5mm hole through top 2 washers (plus handle on one) for 4mm x 0.7 bolts to attach threaded dowel pins. You would need two different length 4mm x 0.7bolts: 15mm and 20mm for the one through the handle
careful with handle, its precision ground with SHARP edges, best to chamfer or wrap!
~48mm ID
~86mm OD,
~4.8mm Thick
9516K273 $15.35
2958A83 $2.10
8305A17 $6.75
2896A25 $2.30
