Press the homelink buttons 1 & 3 for about 10 secs to clear all codes. After that get garage remote and press the open or close button and immediately press homelink button one and hold it. Make sure garage remote is right underneath the mirror. You will see the red light flash slow and when it's programed, it will begin to flash fast. Repeat the same thing for the other remotes. Usually gate remotes for apartment complexes don't work.I’ve tried everything under the sun to get my homelink programmed but it’s not working. Both “point and aim” and rolling code programming is leaving me frustrated.
Anyone else have issues/advice?
Unless you're in Canada. Then instead of holding the remote button down you press it repeatedly hold it in for 2 seconds at a time. So press for 2 seconds, release and repeat.Press the homelink buttons 1 & 3 for about 10 secs to clear all codes. After that get garage remote and press the open or close button and immediately press homelink button one and hold it. Make sure garage remote is right underneath the mirror. You will see the red light flash slow and when it's programed, it will begin to flash fast. Repeat the same thing for the other remotes. Usually gate remotes for apartment complexes don't work.
Sent from my SM-G955U using Tapatalk
I've been successful with the car off.OK hold 1 & 3 button longer like 15-20 secs. The codes didn't clear. Make sure to hold remote underneath homelink when pressing buttons too. Make sure key is on as well. Not sure if that makes a difference.
BigOak were you able to get your Homelink programmed? I do have a similar issue. Tried it several times and nothing seems to work.Held button 1 and 3 to clear, got a rapid green blinking light.
Ended up clearing my garage opener entirely, reprogrammed my remotes and the Subaru, held my breath...nothing. No dice, nada, not working. Warranty? No clue
Thank you! After futzing with my opener and homelink buttons for about 45 minutes, I found this thread and finally got it to work by following your instructions.I struggled with this as well for about 2 hours (which is long for an IT guy). Here is what I have:
- 2019 Toyota Highlander Limited
- Genie Pro ScrewDrive
Here are the steps I used to get it to work:
- Clear HomeLink with buttons 1 & 3
- Train HomeLink button with an existing hand-held garage door opener (before trying to train)
- THEN, press the train button on the Genie, and go back in and do the press-hold HomeLink button, 2 sec, release, repeat twice
The link I used to follow this process was directly from the Toyota support site, you cannot skip the hand-held garage door opener holding a few inches away before trying to directly use the train feature on the garage door opener. Here are a couple of links, follow these to a tee and it works:
https://homelink.com/program/instru...543/144/0/0/39/0/4/intellicode1/0/0/usenglish
https://homelink.com/toyota (Select the "Genie" training video)
I went through all of the same things listed in this thread below, and the above is the only thing that worked for me. Hope this helps someone!
