1 - 2 of 2 Posts
i purchased the ss auto chrome header of ebay for $200 for my 1991 na. the car seems to pull harder all the way to redline. the only bad thing is that it eliminates the catalyc converter and i live in an area that as e-check. the install was pretty simple it was just getting the old exhaust off that was difficult with all the rusted bolts. it bolts up to the stock exhaust and uses the stock hanger. the only problems i had were the new header had two oxygen sensor holes. i just purchased an oil drain plug to block off one hole. the other problem was the gasket wouldn't seal where the old and new exhaust met. they provide you with a flat gasket but need to use a circle o-ring type exhaust gasket
1 - 2 of 2 Posts
