That’s really the only option, painting will probably look even worse.Replacing the whole pannel is a last option for me. Thanks.
"the right paint" I can't find a perfect match for the color of the door panel. the interior trim code is fb11 but from what im reading online that doesn't indicate the color for the door panel.SEM:
Flexible Coatings | Refinish | SEM Products
www.semproducts.com
Use an adhesion promoter and the right paint (for hard plastic or soft vinyl) and sheen and it will be perfect!!
i called and they said toyota doesn't sell any and to call body shops. i called body shops but they say they don't make interior paint colors either.Check with your local dealers, they might have vendors that they work with on their used vehicles who can do repairs like that. Even some paint shops can do that, check with the ones close to delaerships; a lot of the plastic parts on the vehicles come in black and painted to match the vehicle interior colors!
i can't verify an exact match so it probably would just look worseI’d try to find the closest paint color for the door panel.
May need to resort to this.https://www.duplicolor.com/product/vinyl-and-fabric-coating/
It is not a part that Toyota sells! Often times when dealers and used car lots bring in vehicles, there maybe scratches on the outside or inside of the vehicles. Instead of replacing the parts, like your door panels, some dealers' might have someone in their used car department to make the repairs, or sublet it out to paint shops to have the part repainted! Some detail shops will also have similar services; they can spray paint the areas without even removing the door panel!i called and they said toyota doesn't sell any and to call body shops. i called body shops but they say they don't make interior paint colors either.
You will have to find the SEM color chart (35 or 50 or somethings choices) and find the closest match. Plastics fade. Paint fades. Even if you found the exact color it won't be a perfect match. You can't spot paint it. You will have to find the closest color and paint the WHOLE piece........and no one will ever notice!!"the right paint" I can't find a perfect match for the color of the door panel. the interior trim code is fb11 but from what im reading online that doesn't indicate the color for the door panel.
Bets on the junkyard. As long as it’s not damaged.So I actually found a "perfect match" online at leathermatch.com. (TY6794 Dk Gray) is the color code in case anybody is interested. Apparently it's the same color as the seats. Only problem is that it costs $60 for the kit and my local junkyards cost $20 per door panel.
it is just discolored from heat gun use. i will give that a shot actually. i have actually seen youtubers using a heat gun to restore plastic parts (That picture is very small and low res, I can not see what kind of damage it is. Have you tried any vinyl restoration products on it like car guys plastic restorer?
One think to keep in mind, when you go with the paint code, the color you receive matches the original color when new, does not necessarily account for fading! Might want to test it before using it!
At the same time, unless you spray it on, the touchup area would look patchy!
That is also why suggested paint shop, they can match the color to what you currently have!
What do you guys think about the heat gun method I linked above?Bets on the junkyard. As long as it’s not damaged.
If you can figure how to remove the cloth insert, then you can pop yours out and insert it.
