1 - 3 of 3 Posts
You mean the condensor (a/c radiator) ?
Not too difficult. There is just one way not to do it : by the front. Just unbolt the (water) radiator, move it (without removing water hoses, not easy but possible), disconnect a/c lines and slide the condensor towards the engine bay. If there is still not enough place remove the fans (attached to the radiator) and you should get well enough place. Good luck ! (and welcome to TN ! ;) )
99 Camry
You forgot the most important part... GET THE FREON evacuated!!!
1 - 3 of 3 Posts
