Do you know if it is just tape holding it on. Some cars they use pins that go into the metal. I dont want hole's after it is removed. Dealerships are closed today as it is sunday so I cant ask them.
If you have some kingsford charcoal lighter fluid at home, you know, for BBQ!!! use it and save $5 for goo gone. It's work as good as goo gone or even better... :thumbsup:
So, I used a heat gun on low heat and applied it for about 45 sec to 1 min.
I was able to slowly pull the name plate off no problem. Removed some of the glue with my fingers and methly hydrate and varsol worked excellent.
Applied some turle wax after and can even tell there was a label there.
Thank for the tips.
Open up the hood and look at the back of it. You should see clips holding it in place. Just use a flat-head screw driver to pry it out while you pull from the front.
