1 - 10 of 10 Posts
I know this is a noob question but how do I remove the stock shift knob on the automatic trans? I searched all over the place and couldn't find a definitive answer. You just unscrew it to the left correct? I already tried but didn't apply much pressure because I didn't want to break anything.
05 Tacoma
Just unscrew it and you should have no problem, what are you replacing it with.
/\ + 1
Just unscrew it, left loosy, righty tighty!
Go Sharks!!!
06 tacoma prerunner
yup just twist, at least you got the twist direction correct. When you first remove it, it's tight, because i believe the knobs have a plastic sleeve that the threads cut into when you first apply it, making it really tight to remove the first time.
Well I ordered a grenade shift knob from eBay and I specifically told the guy I needed it to be M12x1.25 and he said he could do that for me. So I just got it in tonight....and the guy even had a piece of tape wrapped around it that said 12x1.25. But it is no where close to fitting! What an idiot. O well I'm goin with the cheap way and am going to put duck tape around the shifter so that the grenade will fit nice and tight lol.
Softball God
07 Tacoma V6 SR5 DC
Good to know. I just ordered a Hurst pistol grip tonight.
Mine was a bit loose from the factory. When I tightened it up, it was about a quarter turn off center to the right.:eek: Threads must have been cut weird or something. So I took it off and used a little locktite. Now it's centered and tight as well.
trail monger
05 Tacoma
post some pics of your aftermarket shift knobs!!
tacoma
just a idea but if loose
what about teflon tape ( pipe tape) on the threads
can be removed if needed but will hold tight and cost about 50 cents a spool
Discussion Starter #10
I might try that. You just get that from the hardware store correct?
I'll try and post some pics up but won't be able to until around 5:00 today
1 - 10 of 10 Posts
