Hi, I have a 94 camry. The rubber bushings in the upper dogbone stabilizer/mount are pooched. I got a new dogbone, but am not sure how to replace it. Looks like it is held in place with two single through bolts. Do I just remove the bolts, drop in the new dogbone in, and put the bolts back, or is there more to this job than meets the eye? Does the engine need to be supported before removing and replacing the dogbone? Is aligning the new dogbne difficult? Thanks, Glenn
