1 - 3 of 3 Posts
Need For Speed
2011 Camry SE
If you google it, there are sites out there that will show you a step by step process. That's how my husband and I do it when we replace radios in our friends' cars.
06 camry se
take a flat head screw driver to the bottom of the HVAC controls and pry upwards on either side; then grasp both sides of the vent assembly on the bottom then near the top where the clock is; pull being carefull not to break the clips or crack the assembly; the clock is connected my a simple conector; to remove the radio there is 4 10mm bolts then 3 electrical connectors
1 - 3 of 3 Posts
