There is a few screws.. One take off the a piller thing, its just clipped in and is easy to take out. 2 there are a few screws that hold it in. there are 2 below the door at the bottom easy to take out. There is a circle of plastic near the top where the door connects to the car, pop this off with a flat head and take that screw off. Now where the door unlocks and locks, behind the handle, that is a plastic cover, remove that and take off the screw behind it. There is one more, where you hand goes to hold and shut the door, there is a rubber bottom, remove that and there is one more screw. After that there are clips that hold the door on, just pull firmly but strong. i again would recommend the flat head screw driver. and you will have the door come off. I still cant believe that there are 6x9's in the door, they are huge.
Shuluke
