1 - 4 of 4 Posts
I need to check the timing on my 89 camry 4cyl. I've searched the posts, but can't find a clear answer. Do I need to take off the timing cover (big job) or is there another way?
What should a healthy, stock timing read for this car?
· Grenaded piston
Ignition timing:
1. Start car and jumper pins TE1 & E1 on the diagnostic connecter under the hood.
2. Place tranny in neutral. Make sure the parking brake is set.
3. Hookup a timing light to the #1 plug wire. Stock setting is 10 degrees BTDC.
Crank and cam timing:
1. Remove upper timing belt cover.
2. Rotate (clockwise) the crank to TDC (0 degrees). You might have to rotate the crank 2 full turns depending on where the cam is at.
3. Check the alignment marks. Crank pulley should be at 0 degrees. And the hole on the cam gear should line up with the mark on the bearing cap behind it.
1 - 4 of 4 Posts
