1 - 4 of 4 Posts
I need to install a new stock grille into my 1994 Camry LE. How do I install a new grille?
kor-ro-ra?
97 Corolla 1.8L 5spd
Remove the 2 Screws holding it in. They are located on closer to the headlights just use a + screwdriver takes all of 10 Seconds.
Discussion Starter · #3 ·
Thank you.
Exactly what midnightmatch said. 2 hex head bolts and then it lifts out. I forgot whether they are 10MM or 12MM. You will have to unscrew the Toyota emblem form the back side of the old grill and place it on the new grill. That's 2 small phillips head screws. They can be a bit rusty at times, but are only screwed in to the plastic.
Mike
1 - 4 of 4 Posts
