Own Tacoma2007, what should I install to get handle more weight. Should I install air lift or leaf spring stabilizer or anything else. I'd like to load up to 2000 lbs. Any suggestions. Thanks
I concur.^Exactly right.
Why would I need a rear TSB or AAL even with air bags. I dont think that is necessary. The air bag are attached to the bed frame and frame of the truck. When the bag are inflated, it takes load off of the springs, it does add any other pressure. Weight is placed on the bags.Even with air bags you'll still need to beef up the leafs. Either with the rear leaf TSB or with a add-a-leaf. Don't forget you'll need to beef up the tires too. Load range C is minimum, Load rang D will be more stable.
