1 - 20 of 23 Posts
03 CAMRY XLE
I acquired a 98LE in 2007. It had about 45 kmiles on the meter. A dealer inspection at that time pointed out a drip of coolant from the water pump weephole. So grab a flashlight and take a careful look around that area.
· Administrator
Impossible to say with any certainty. The original pump on my V6 Camry went well over 200k miles before it started weeping coolant. And I wasn't all that great about changing the coolant.
If it dies suddenly, it can leave you stranded. So replacing it before it goes depends on how much of a hardship that would be for you. And, if you drive in heavy traffic a lot, having the engine die suddenly and losing power steering and power brakes can be hazardous.
My Gen 1, 1984, purchased new, had the water pump to seize without warning at 37K miles, just out of the warranty mileage. Broke the timing belt. With towing and the dealer ripoff, it was very expensive to get repaired. Got rid of the car at 147K miles.
Now a new water pump is installed with every new timing belt on my cars.
Hard to say but at that mileage I'd invest in doing the water pump, timing belt and oil pump seal all in one shot. Three problem areas which can be addressed before you're stranded somewhere.
Look in sig
Most times you'll find out that your leaking a crap ton of oil from the worn seals or the notorious oil pump gasket AND seal is leaking for the 2.2L engine
But yes, they can fail anytime and sometimes rather early. Both the 2.2L and 3.0L engines for this generation Camry does not have any common water pump issues thankfully.
If the timing belt, water pump, seals, and oil pump gasket/seals are not done yet, might want to consider that to get done if you plan to keep the car for a bit.
If your service schedule has been followed you are due for a timing belt in 13K. If you don't have the classic signs of a leaking water pump I would just plan to R&R one when you schedule your timing belt job at 120K. And as has been mentioned look over the oil pump area as I would suspect you are probably due for at least the oring gasket and potentially the oil pump shaft seal gasket. Again all easily accomplished when you have the front of the motor exposed. Generally water pump service life is predicated on proper engine coolant changes.
· 500,000 + Miles
2000 Solara
There are clearly some outliers as some members have shared so you have to do what best meets your needs to reduce the danger of being stranded or being without a car for a day or so. That said, I think it's age more than miles that determines how long some parts last. I replaced my water pump for the first time at around 300,000 miles and it was still doing its job without leaking. I would have been hard pressed to detect any difference in the "feel" of the bearings in the old and new pump. I recently replaced the cam and crank oil seals and there was a HUGE difference between the new and old seals. The old seals were hard and brittle. It wasn't the mileage that made them hard, it was age.
· Administrator
No doubt, but I would add that heat is a big factor too. When I replaced the valve stem seals on my 3VZ, the old exhaust valve seals crumbled like dried up peanut butter. The intake valve seals were in much better shape, but still very hard compared to the new ones.
Reactions: Toyota_JP
· 500,000 + Miles
2000 Solara
Agreed on the temperature factor...the oil seals are probably subjected to a lot more heat. BMR, I didn't realize the valves had seals other than the metal guides they operate in. There are some non-metallic seals in the valve guides now?
· Administrator
Yeah, those valve stem seals probably have the roughest life possible for an elastomeric seal. Here's a pic of the new ones when I was doing the HG job on my 3VZ. These sit on top of the valve guides.
1 - 20 of 23 Posts
