I own a 2004 Toyota camry and got 106k on it.
That's about 10k miles a year...not very many and THAT CAN be a concern when it comes to regular maintenance...
How long can I expect the car to last or how many more miles if I regularly do maintenance?
Many owners, TOO MANY owners, underestimate wear and tear OVER TIME vs. mileage....
What have you done thus far....?
IN THESE TEN YEARS...
How MANY TIMES have you changed coolant, flushed and changed other fluids, incl. brake, power steering, auto-transmission....? They break down chemically over time and should have been changed at least 2x by now...
Have you checked/replaced as needed all rubber components...hoses, gaskets, engine mounts...?
Have you changed your PCV valve and spark plugs, and valve cover gasket(s if it's a V6)?...they do dry out and become brittle, and their sealing capacity becomes compromised....
I am in the middle of making the decision of whether I should get a new car leaning towards a honda fit, or to hang on to the car.
How many miles do you have on your camry, and have you had any major problems?
Also is it safe to take the car with over 100k on road trips (800 miles)?
I bought an 05 that ran great with 97k miles but did all the maintenance above regardless of whether (or NOT) the previous owner had...just to make sure they had gotten done...and they really needed to be done....
I've switched from conventional oil to synthetic and the car runs even better now...a few months ago I round-tripped from south Florida to Chicago (1400 miles) each way in two days non-stop (other than for gassing up) each day...and it actually used LESS oil on that 80mph run than around town, a reversal of what I had previously experienced...and averaged 35-36mpg at 75mph cruizin'....
I too will run only 10k or so miles a year...and by spending a few hundred dollars a year I expect the Kitacam to run for at least 15 years...to 250k miles...I'll likely have to up that annual cost as I get up there in miles, for suspension parts, for a new clutch.....but that's what's to be expected in terms of regular maintenance down that long road...
Welcome to TN and hope we can help you down that road if you stick to your Camry....
