No way its 30 lbs. Even a flywheel for a V8 doesn't weigh 30 lbs.
I'd say about 15 lbs. or so. I believe the Fidanza flywheel is about 7 or 8 lbs.
It was definitely over 15 lbs. Had to be at least 20. And the Fidanza flywheel weighs 10 lbs according to their site. The clutchmasters unit weighs 8 1/2 lbs but costs about 100 more than the Fidanza unit. I have heard lot's of bad things about the FIdanza one destroying itself though.88 LE said:No way its 30 lbs. Even a flywheel for a V8 doesn't weigh 30 lbs.
5Sfte said:Isn't Wraith using the Fidanza unit?
the word WAS using a 9.8LBs Fidenza flywheel for the MR2 turbo...5Sfte said:Isn't Wraith using the Fidanza unit?
Are you using, a lightweight crank pulley? I have already seen that monsterous clutch setup. You are the man Wraith!Wraith said:the word WAS using a 9.8LBs Fidenza flywheel for the MR2 turbo...
