1 - 20 of 49 Posts
Corolla 7g
i tried for the umpteenth time over several days now and still a NO GO!
338597
is there a trick to employ
what would you do??
yes, it has stopped leaking fuel since this pic was taken after the tube kinked bad on a soft spot
pic of the fitting opposite
338598
Administrator
マズダスピード3
I would do the 2 wrench trick. Put one on the small but and another on the large nut.
1997 Corolla
In the first picture it looks like you have the wrench on the part that doesn't turn. That is just to there to hold it in place. The smaller nut turns. Sorry, if you already know this.
Discussion Starter · #4 ·
Have you dealt with rusty crusty like this :ROFLMAO:, it's on there good!
Soaked it for two days at least in transmission fluid, I heard about doing that before and it didn't work yet
Yes, I was using my crowfoot 19mm with ratchet to apply opposing force (to keep that discontinued piece from turning) and possible kinking because I have no clue what the pipe material is made of! It's not highly corrosive like all the other tubes are, I don't get that at all!!
Then I was using a channel lock pliers to firmly grip the crusty tube fitting and turn counterclockwise as the usual, unless the turn is different for this line? But all the force I could muster was not good enough.
The fsm diagrams for fuel lines looks to be a torque of 30 Nm
Administrator
マズダスピード3
Guess the crust wins this time.
Discussion Starter · #6 ·
Car is broken down until it gets undone and new tube line hooked into
So it cannot win lol
Administrator
マズダスピード3
1997 Corolla
Using channel lock pliers may be squeezing the nut onto the pipe and making it harder to turn. Why not use a flare nut wrench on both at the same time?
Discussion Starter · #9 ·
i will have to look at the new tube again to get a reference on how the nut could even do that !!
at first i tried the flare-nut crowfoot with a ratchet on the main tube while holding the outlet pipe with channel lock pliers, and ended up twisting the line bad fuel leak lol
Discussion Starter · #10 ·
is it at all possible that threadlocker loctite was used at point of the assembly of this fuel fitting ?!?!?!
Discussion Starter · #11 ·
nephew gave it a better shot than i with the newly picked AZ flareNut wrench 14mm and still a NO GO
and that connecter even started stripping, was not TITE in the flareNut wrench like the new tube fitting is!
what to do now?
339112
Discussion Starter · #12 ·
Discussion Starter · #13 ·
the other end...
talk to me, TN
339479
339480
Discussion Starter · #14 ·
The fsm instructs this to be torqued to 30 Nm
SST. 09631-22020
Discussion Starter · #15 ·
Discussion Starter · #16 · (Edited)
duplicate
Discussion Starter · #17 ·
I do not possess a replacement fuel pump in tank bracket to even begin to understand how the puxk it turns and fastens at fitting
Need outlet line off to torch other side, this is the goal
1997 Corolla
I would put a good flare nut wrench on both parts with a slight angle between them then just squeeze them together with 2 hands and hope for the best. Just make sure you are turning them the correct way.
Reactions: 97tacomaHA
Discussion Starter · #19 ·
do both of the fittings Turn? or does one stay stationary not able to turn?
somebody must've had to replace fuel pump before and needed to undo this part to get the pump bracket out of the tank!
Discussion Starter · #20 ·
i find it difficult to fathom that Nobody here has removed & replaced a fuel pump and can offer up which one of these fittings turn and which one is stationary, or do they both turn? and how difficult it is to remove without twisting too much if its never been undone before
10d...
340554
1 - 20 of 49 Posts
