Does a Carb add good power and if so, how much?
why wouldn't you go over 2''?its not the fuel that nets you the HP its the amount of air being pushed threw the motor, but a header and eaxust you would definetly feel the gain i wouldnt go over 2" on the pipe
in exhaust system design and theory there is what is known as the "scavenging effect". the pulses of air being forced through the exhaust system carry their own amount of inertia and will have a small vacuum behind them. that small amount of vacuum can be used to help the other pulses move through the system. if the pipe is too small, its choking the system. if its too large, it is too big for the scavenging effect to be effective. if the diameter of the pipe is the right size, it works throughout the operating range. in the case of the 22r engines, 2 inches seems to be about right. the gains are in the few HP range, but they are there. and relatively easy to get.why wouldn't you go over 2''?
Interesting, never heard that, i always heard the bigger the pipe the better, less restriction.in exhaust system design and theory there is what is known as the "scavenging effect". the pulses of air being forced through the exhaust system carry their own amount of inertia and will have a small vacuum behind them. that small amount of vacuum can be used to help the other pulses move through the system. if the pipe is too small, its choking the system. if its too large, it is too big for the scavenging effect to be effective. if the diameter of the pipe is the right size, it works throughout the operating range. in the case of the 22r engines, 2 inches seems to be about right. the gains are in the few HP range, but they are there. and relatively easy to get.
Then why do dragsters run it straight off headers.I ran my truck race truck on a chassis dyno last year. It made more torque and power with a section of 2 1/2" pipe that ended in front of the rear axle than it did with an open header. The legnth of pipe helps "pull" the gasses out.
What planet do you live on in which catalytic converters are for performance....I had a Chevy 350 with a 3.5’’ pipe. With no muffler I got moor power. With my 88 22re the best for power and fuel economy is 2.5” pipe small muffler and a flowy cat. Whey better to have a cat then not
Big engines don’t like bake presser little engines need some but not to much
Plus if u can find the pipe race specs (which I cant for my toy) they will tell you the length in mm to get blow back, header pipes usually need to be custom. Blow back is when that half a millisecond between a cylinder firing their is a vacuum that pulls a small bit of air up the tail pipe and in to the combustion chamber.
i think you need to review the workings of the otto cycle engine. "blow back"? 3.5 inch diameter on a 350? really. header pipes usually need to be custom. i really do not know what you are talking about. do you?I had a Chevy 350 with a 3.5’’ pipe. With no muffler I got moor power. With my 88 22re the best for power and fuel economy is 2.5” pipe small muffler and a flowy cat. Whey better to have a cat then not
Dragsters engines are built for peak HP at one rpm, even the dragsters need that short section of pipe...my engine is bult for low end torque and a wide power band. For a street 4cyl, you just are not going to flow the air like a top fuel dragster.Then why do dragsters run it straight off headers.
many reasons. weight and ease of access being one of them. nobody wants to fight a header off in order to pull a head between runs. i have done it and it is a real pain. another reason dragsters run the exhaust the way they do is to have the ability to spot a dead/misfiring cylinder while it is running down the track. if you watch drag racing, you will see what i mean.Then why do dragsters run it straight off headers.
If you run an engine with steel valves, nothing bolted to the head, and a cam with a lot of overlap...you will warp the exhaust valves. In an open wheel dragster, I don't think you'll worry about fumes in intake above 10 MPH. I never said anything about the primary tube size.I believe you are wrong, The short piping on exaust is to keep the exhaust fumes away from the air intake. That little ammount of tube is not going to server any other purpose lets be serious here. because then i could say that " My headers have 1inch tube for each cylinder so its causing mega suction"
