1 - 4 of 4 Posts
B
Guest
Hi--
As you all suspect, I've moved to a state that requires a front plate.
I've read the other threads in the group on this topic and they don't
really answer my question, which is this. I have the original front
molded plastic bracket that came with the car, so I thought this would
be easy. But it seems like the bracket doesn't even match up to the
bumper. Also, I don't see any indentations marking the screw spots.
Possible problem: 4 years ago on black ice I took this car into a guard
rail. I suspect the front bumper may have been replaced with an
aftermarket part (I told the body shop to do what they had to do to
keep insurer from just totaling car out.) Any advice? I'm thinking with
the car now more than ten years old, maybe I just jerry-rig it on there
any way I can. Thanks in advance for any help.
Q
Guest
Discussion Starter #2
Just mark the plate hole locations with a punch, then put a sheet metal
screw in the bumper.
B
Guest
Thanks, probably what I'll end up doing--but are you saying plate
directly to bumper this way, or bracket to bumper first?
Q
Guest
Whatever you want. You don't need a bracket on the front, but you could put
one. I guess the theory being you only bolt the bracket to the bumper once,
then you can bolt the plates to the bracket as you need. Never really
thought about it, because either way you do it, it won't go anywhere.
1 - 4 of 4 Posts
