1 - 2 of 2 Posts
hi gurus,
i have a 2007 Sienna AWD, my right side foglight is busted, but it said on the manual i have to bring it to the dealership to have it replaced. is there any DYI's out there. thanks!!
more power to you guys!.
sincerely,
Cirinzo
05 Tundra
Cirinzo, you will need a pocket screw driver & a 10mm socket, I drove my 06 up on 6" ramps for I could fit under better. there is a plastic cover across the bottom under the bumper, I never took the cover completely off, just moved it back far enough to reach my hand up behind light assembly. use the pocket screwdriver to pop the centers of the plastic rivots out about 3/16" then pull the hole rivet out, you can reuse them, there are 3-4 screws with 10mm heads to remove, then just gently move the cover enough to fit hand up behind light.
1 - 2 of 2 Posts
