The back of my 5SFE is caked with oil and dirt from years of valve cover oil leaks. There is a bunch of wiring back there and I was wondering is it safe to spray engine degreaser or brake cleaner to clean up that mess?
V=Vehicle. IIRC, It's on the top of the transaxle, passenger side. Need to disconnect electrical connector and blow out. Vertical mounting of connection allows for accumulation of cleaner/water. Don't have any 5SFE cars anymore, so working from year old memory on location.VSS as in Variable Speed Sensor?
If so, curious as to where it's located to help point a nozzle at it to blow it dry?
I've degreaser my motor a few times and never had any issue.....(even in the alternator).....though would certainly look after potential problem components where possible.
TIA
You would probably be better off just spraying the connectors with some WD-40 if you git water on them.No air compressor. Can I just go for a long drive instead?
