1 - 9 of 9 Posts
I have an engine light because of my o2 sensor and dont have $120 to replace it.
So I just want to clean it up and see what happens so what can I use to clean it.
I have wd40 and I also have some denatured alcohol can I use any of these or what
I had good luck using PB Blaster and an o2 sensor socket set, which I picked up at Advance Auto. The PB Blaster just needs some time to do its job before you start trying to twist out the sensor.
Have you considered the Denso universal replacement o2 sensors? I replaced all three sensors in our '98 Sienna back last winter and the sensors were about $40 each from www.rockauto.com. Denso is the OEM brand for our van, which means all the sensor wiring color-coding was the same. This made for a very easy job of replacing the sensors. Not as easy as using the plug-and-play sensors, but heck, those cost a lot more! Try going to the Rock Auto site and enter your vehicle's description, then look under Emissions and see if there is a Denso universal sensor for your model. Since you're going to all the trouble of taking out the sensor, for $40 you can maybe get a brand new one to install in its place!
· 抵抗しても無駄だ
2002 Solara SLE V6
I've always found zero problems in removing o2 sensors even on 124k mile old cars ... PB Blaster, wait 5 minutes and then use o2 socket (can borrow a set from autozone) with a 3/8'' ratchet or better a 3/8'' breaker bar or torque wrench (it's much bigger than ratchet). they come off like butter.
so, which sensor is bad that you need $120 ? upstream AFR sensor (calif specs) ? those are easiest to get to. find them (Denso) on ebay cheap, new OEM ones (no OE fit). Universal ones require splicing or using butt connectors to re-connect them to old plug. it's cheaper than OEM or OE fit though. (as posted above).
find your part number here:
http://www.densoaftermarket.com/catalog/
NTK/NGK equivalents are noticeably more expensive than Denso even when you get them on amazon.
stay away from Bosch OE equivalents, they cause only trouble and do not survive long.
2002 Corolla S
I'm currently thinking of trying to clean mine as I won't have funds to buy a replacement for another week. The real reason I'm necro'ing this thread is the recommendations on how to get the old one off. My mechanics (I'm a plant manager/dispatcher for a concrete company and my location is also where the company shop is) got samples of and then started using in quantity a product called Free. I've taken a can home myself and it has freed everything so far I would normally use PB Blaster for even better. It is not a lubricant also so you'll still want to maybe have some PB on hand but for breaking rusted and to an extent heat tacked nuts and bolts loose I've now found the superior product.
To clean this I'm going to try a combination of brake cleaner and good old heat/cold. Going to heat the tip of the sensor with a torch and then quickly quench it in ice water a few times to break out deep seated carbon and then I will give a healthy soaking with brake cleaner. I've a 2002 with the 1.8 that of course has the burning oil issue and at 160,000 I'm starting to be barraged by p0171, p0130, p0133 and got a p0125 after my last reset. I think the car is telling me it needs at least one new o2 sensor.
1 - 9 of 9 Posts
