How to disable traction control?
985 Views 7 Replies 5 Participants Last post by  Deep
Have a 03 4Runner with a factory supercharger. Can't get the traction control to stay off.... Any help would be appreciated.
1 - 8 of 8 Posts
traction control
yes, it does have a button. The issue is that once a significant amount of power is applied it turns the traction control back on by itself......
You can pull the fuse. :)
I cannot believe that there is no answer for this problem....
What a freakin waste 350+ HP is.... somebody HELP!!!
I'm sure if you read through the wiring diagrams you could find a way to hook a toggle switch up to it. So that you could complete cut power to the device. Not sure how safe it would be... but it should work.
:thumbup:
By doing so, I think it also kills the speed limiter.
1 - 8 of 8 Posts
