1 - 8 of 8 Posts
Discussion Starter · #4 ·
Thanks, If I can remove them, I think I know how to install them :)
BLUEMEANIE, can you please clarify how to remove "back dash"?
I don't think I will have any problems with the bolts at the endlinks....Just that I can't see the upper nuts (I assume there got to be some nuts holding the strut in place.)
Sweet n' Lowdown
2006 Scion tC
lol. Thats the hard part.
- Put the seat down.
- Remove the two little black philips screws that we're covered by the seats.
- Remove the side bolsters.
- Remove the center brake light cover.
- Disconnect the center brake light bulb.
- Remove the center brake light lamp housing.
- Carefully slide out the back dash. (there are little clips on the rear edge of the back dash panel that will rip your speakers if you're not careful.)
It will look just like the front ones, there are 3 nuts on each and a rubber cap on a 4th middle larger nut. Do not remove the middle one til the strut/spring is off the car and you have a compressor on the spring.
...and don't forget to unhook the brake line from the strut first.
The endlinks require a hex (or allen) wrench and a open end wrench.
I also suggest getting a Haynes Manual
A Poor College Student
1994 Camry Sedan LE
If it helps, here's a pic of the upper strut mounts in a 94, as I'm about to install the Tokico inserts tomorrow....
Discussion Starter · #7 ·
Thanks for the write up (and the pic from Wolf).
Good thing I don't have to work on it all the time....that's lots extra hassles just to get to the nuts.
(No haynes manual...though I probably should get one...it is cheap enough. )
1 - 8 of 8 Posts
