If you're referring to the outer taillight assembly see link > http://www.toyotanation.com/forum/333-3rd-generation-2014/1272377-how-replace-brake-light.htmlI followed the manual and I removed 2 screws on the tail light assembly. I tried to slide it out but it didn't help. I don't want break anything if I try harder. Any tricks for removing the assembly?
yes. thanks. I tried that but it was hard to replace. I didn't want to break any clips or tabs if there are anything.If you're referring to the outer taillight assembly see link > http://www.toyotanation.com/forum/333-3rd-generation-2014/1272377-how-replace-brake-light.html
Just slide it straight back to remove. There are clips/tabs in the front and the two screws in the back. When replacing make sure the clips go in first, then put the screws back in.yes. thanks. I tried that but it was hard to replace. I didn't want to break any clips or tabs if there are anything.
