Recently my speedometer has begun to give a higher MPH reading than actual speed. All other gauges work fine. I tested that it was the gauge cluster by swapping it out with a known good one, and the replacement worked correctly. So it's definitely my original speedometer that's no good.
I've read that the speedometer alone can be replaced. I would like to keep my original odometer, but I'm not sure if the speedometer/odometer combo is one piece or if it can be separated. Does anyone know if they can be separated? Can anyone provide some guide on how to make that repair?
:help:
:help:
