1 - 3 of 3 Posts
Can someone help me out? I have an 05 camry xle and the front turn signal/ marker bulb burnt out and can't figure out how to replace it. It looks like the entire headlight assembly needs to come out. Anyone ever change it? Can you tell me how please? Thanks
On my Gen6 i had to go through the wheel. You have to remove the cover inside the fenders a little bit and reach in. You should have done a search because there is another one of these threads with a bunch of replies.
It's Soo Hoo like Yoo Hoo
the pass. side bulb is a little easier to remove than the drivers side. The bulb is attached to a thin twist-type holster. Once you twist that out, you are good to go. If you have big hands like me, you may need to remove the battery to access the drivers side. I was able to do it without removing the battery but my hand ended up with a crapload of scratches and bruises.
1 - 3 of 3 Posts
