1 - 8 of 8 Posts
hi ppl im new to this site and i would like to know if anyone can help me taking off my door panel fer my 2001 camry i took all the screws out and the panel is loose it seems like the handle tht u open the door with inside the car is holding it from getting off all the way. How would i loosin that up or take it off so i can get the door panel off?
Whine Connoisseur
Assuming you're refering to the inside door skin/panel...make sure you're removed all the screws. There's one inside the handle that is hidden behind a plastic trim cover. The rest of the screws and clips should be pretty easy to find.
2000 Camry LE
the door panel is a mother f. to get out. the bezzel should snap out, i remeber when installing speakers for the front door, pulling the panell upwards, maybe that might help.
Discussion Starter · #8 ·
thanks Phi you helped especially you braught up the bezel and thats what it was, i used my common sense a little and got the bezel off and then i got the panel off. and thanks fer trying to help guys.
1 - 8 of 8 Posts
