1 - 5 of 5 Posts
so i have to order an intake hose from toyota, because apparently it is a "special order" item. so for now i have used duct tape to seal the crack untill my hose comes in. well, the bucking problem that i had when i would start out in first gear, it would just start bucking, horribly. and now since i have taped the crack it doesnt do that anymore. can someone explain what was going on? why would getting to much air cause it to buck?
· The Regenerator
2018 Prius Two-Eco
The ECU's attempts to measure the variables that impact upon the engine's performance, and to respond accordingly, are being frustrated by the leaking hose. The engine, obviously, is not designed to operate with the crack and leak. The ECU does not "understand" that there's a crack there, and it's trying to make corrections while assuming that the engine is configured as it was intended to be. But it's not.
· HID/Retrofit Expert
2002 Camry LE
^Don't forget to add that if the crack is behind the MAF sensor, the sensor thinks that you're getting less air than you actually are.
· The Other White Meat
Holden Apollo
its like someone slipping youa drug in your drink at a night club =)
you and your brain will act all funny because of the foreign... stuff... that you didnt know about =)
1 - 5 of 5 Posts
