i picked up a set of hx rims from a local salvage yard. they are the eom wheels from the honda civic hx, the enkei A-1 m's .. 14 x 5.5, 4 x 100. the only problem is that they only clear the calipers by 1/16" ... and thats not good. so, i found a set of spacers, which are 1/4". i have always liked the hx rims, they are light, and they look good as well as being rigid. they are a good low budget solution to having something better than steelies while u save up for better wheels. a decent set can be had for about 100 +. i paid 100 for mine, but one wheel has some curb rash, but i am planning on polishing that out. 4 x 100 honda wheels fit fine on yotas. its the opposite that doesnt. the hub spacing. im sure you experienced readers are familiar.
i found my 88 corolla gt-s back in november 07 on a craigslist posting, immediately researched what it was, and was quite shocked to find out it was the younger, front wheel drive little brother to the RWD corollas. it had some front end damage and the previous owner didnt have the time to deal with it, and the need for a parts ae92 either sr-5 or gt-s could not be met by any of the local yards. a LH collusion with a gaurdrail resulted in a dented in LH fender, headlight asembly, hood, and worse, a bent in radiator support casing, and a bent in inner fenderwell. as i was towing it home, one of the dryrotted tires skipped my eye during preroll inspection, because the belt came off and was flapping around..this resulted in knocking off my RRH mudflap, and leaving a bunch of nasty gunk on the quater panel.
So, i got lucky and found an sr5 @ the scrapyard right down the road, where i snagged up the hood, fender, headlight assembly, tailights, and the LH and RH marker light assemblies( thank god they are the same for both cars) so for the past few weeks its been undergoing its restoration process. my goal is to return it to stock, but of course go ahead and add i/e/h and ignition coil/wires/plugs, and do the afm mod to fool the ecu. im assuming itll be a year before i can start the next phase of more important things, like new bushings, shocks, coilovers and camber adjustment. and for the engine, thats what i need some help with. i am thinkning that a 4agze with the smaller supercharger pully, a thinner headgasket, and cams from the 16v bigport... dunno yet. i do believe my bigport has good n/a potential, but im not sure what would be more costly...getting a smallport block for the 10.3:1, slapping on my bigport head(milled), thinner gasket, and of course i/h/e. i dont like turbo b/c of its spikeyness and all the extra plumbing. but i do want to be faster both on the highway, and up in the mountain roads, then say a wrx or talon tsi. that should be possible because of the wieght difference. but the main reason is to find just the right amount of power. i live in mountainous hilly area, and i need uphill power, but manageable in the sharp turns, not lag and spikes from turbo.
I would definately be interested in any formulas for an n/a 16v bigport build, and for the s/c build. i have found a few myself so far, but prices vary from here to there. so anyway, here are some pix of the progress:
here are more shots of the damage, you can see how its off...
heres a pic of the goods, a LH fender, hood, headlight assembly, marker lights, front grille, and hx rims:
here's some pix @ the shop, we bent back the support casings for the radiator and fenders ...
we got everything str8, now its just a matter of fixing the metal on the casing for the headlight assembly and reattaching the body peices...
heres some shots of the HX rims:
im thinking it may need longer studs.. dunno yet. will know when i mount the spacers.
i'll update as i go, she should be on the road soon =]
