Well the thing is i don't have any concrete plans for the car, but would like it to reach ~350hp over time, part by part, and since the stock turbo is dead i need another so i'm thinking why not put a larger turbo to start with that. The problem is now, will the car lose performance greatly due to the larger turbo or will it sustain performance regardless of it. I'm pointing out that i would set the new turbo to stock alltrac pressure. Yes, the turbos i'm currently browsing are quite larger than the ct26.
(example specs:
INLET 3"
OUTLET 2"
MAX PSI CAPACITY 28PSI
COMPRESSOR wheel diameter 53.90/69.31 mm
TURBINE wheel diameter 63.98 / 73.89 mm
MAX HP 450HP
turbine wheel trim 1.12)
I don't know that much about turbo mechanics so this data voids my knowledge that is why i need help.
