1 - 18 of 18 Posts
92 Camry LE V6
Damn.....I rebuilt my engine using the old head bolt thinking it wouldn't no harm. And guess wat, its leaking from the start...this sux ass
92 Camry LE V6
Discussion Starter · #3 ·
Yeah......all I can do now is use some head gasket repair till the summer and pull the whole thing again. Man this really sux. Can anyone recommend something for a temp fix
sorry to hear it...
Doing a head job is hard, hard hard...I always prefer to find a wreck and just do a straight swap...not much help to you now, but I did want to say thanks for sharing your experience, you might save someone from doing the same.
Best of luck!
OldSchool Yota Enthusiast
Temp head gasket fix?...hell yes!!!
Its called IronTite. Its a ceramic motor seal that you run in the rad with straight water for 3 days, then drain completly (block too if you can) let cure overnight, then refill with antifreeze the next day.
I bought a car with a blown head gasket and this stuff sealed it up for six months until I could find the time to fix it properly. I'm sure it could have gone a lot longer.
I heard about it from an old time engine builder who ran a chevette with a blown head gasket for 6 years straight using this stuff. Once a year it started to leak again, so he put in another bottle!
Freakin amazing stuff. Definatly the only quality temp fix I have ever seen.
When I tore my motor apart you could see my head was warped bad. You could see where the seal filled in the huge "gaps" between the head and the block.
I wouldn't use it as a perm fix, but if your in a crunch or stranded, this $14 bottle will get you home instead of paying that rip off shop a ridiculous amount because you have no choice.
Make sure you get the one that you add with straight water, not the one you add with the antifreeze. Read the back, you will see. The parts store should have three different bottles lined up. One you add with antifreeze, one you add with water, and a cooling system flush you use after the final repair has been done to get the stuff back out of the system. Make sure you get the right one.
One thing though. Re route your heater core lines to bypass the heater core (just for the initial three days). I learned that the hard way.
Hope you take this advice. I'm very confident it will work...it did for me, probably with more of a major leak then you too.
92 Camry LE V6
Discussion Starter · #8 ·
Thanks everyone and your welcome Sheepish, I hope this thread do help someone realize not to use old headbolt. Man all that hard work and money GONE. n I just got done swaping a E153 Too!!!........Guess I just have to wait till summer to redo everything
bump...I think you missed my post above yours...posted at the same time.
92 Camry LE V6
Discussion Starter · #10 ·
Oh sh*t really Rob........Man you just gave me some confidents. Where can I find these stuff. is it @ autozone?Checkers?
I'm in Canada, so I dont have the same stores. I got it at Lordco up here. Try a couple auto parts stores, if not not, i'm sure you can get it online.
If your really stuck...pm me and i'll buy a bottle and send it to you if you paypal me the total.
92 Camry LE V6
Discussion Starter · #12 ·
I'm sure I can find it or something similar to it herein the U.S. It would be to much trouble, plus I don't have paypal:lol: Thanks so much though. Good looking out.:thumbup:
89 p'up
mmm, stop leak, yuck. temporary fixes have always led to permanent problems in my experience.
pepper in leaky radiators, sawdust in transmissions, heavy oil in engines, and here in the USofA you can have any part you need for a toyota delivered to an autozone (or stealership) within 48 hours.
engineer in training
I want to say any kind of epoxy sealer is not going to work but I'm not sure because most people are willing to shell out the money for new head bolts even though they cost a bit. Those old head bolts wont hold very much of the torque necessary to generate a good seal but who is to say otherwise, few people ever reuse old torque to yield head bolts.
Congrats to you for trying to save a buck, now you have to tear it down again AND buy a new head gasket. Hopefully with new head bolts this time.
No no...I'm telling you, there is nothing "similar". If you cant find it, dont bother with anything else. But there you go, buddy posted a website above.
Here it is, the first one on the page below..."Ceramic Motor Seal" :
http://www.irontite.com/adds.htm
V8'sRGone
95 Cam
What went wrong?
Core issue:
There is a LOT of failed HG after rebuilds. Between the TTY bolts and attention to preparation, it seems it could be avoided.
What I want to know is how many of you who had secondary failure did each of the following?
1 - Cleaned the bolts spotless clean (threads and flange)
2 - Cleaned the blocks threads removing all debris, chased threads, blew out debris repeatedly. Cleaned every hole with solvent!
3 - Ran a head bolt into every thread to ensure it threads by finger to depth w/out binding
4 - Greased the head bolts seating flange and head seating area
5 - Oiled the head bolt threads
6 - Torqued the bolts in multiple steps in the pattern shown in the manual
Skipping any of these steps will lead to the wrong torque and likely lead to a blown head gasket! In addition: use a good quality torque wrench that wasn't used a breaker bar!
Please tell your story so others can learn and see what went wrong.
6 steps, used bolts and had success_____
0 steps, used bolts and had sucess _____
6 steps, NEW bolts and had success_____
0 steps, NEW bolts and had sucess _____
copy / paste
Obviously allot of this depends on the quality of work done by the machine shop and the blocks condition before the rebuild.
Thanks,
73
1 - 18 of 18 Posts
