1 - 16 of 16 Posts
· Don't get mad. Get even.
a Toyota camry, daaa
I need a cluster or face in KM for a 98 Toyota Camry 4 cyl. If I can't get a full cluster, I would like to know how to convert the digital part from MPH to KMH..
Thank you
· TN Pussy Man
Camry
you can't just convert the mph to kph to the best of my knowledge
go on car-part.com and find a canadian junkyard that is willing to ship to the states
1998 Camry CE
Do you mean the odometer, the digital read out at the bottom??
That is stored in the ECM.
Discussion Starter · #8 ·
Anybody know if a speedometer cluster from a 98 Camry 6 Cyl it's different in any way, shape or form than a 98 Camry 4 Cyl or if the are compatible?????
Thanks
· Beware of pigs
Little Pig
Thanks
No physical or pinout difference that I know of. Not sure if the speedo is programmed differently for size differences between 195/70/14 (I4) and 205/65/15 (V6) tires.
Discussion Starter · #11 ·
I found one from a 4 cyl with 103k KM just a little less of my actual miles..
Thank you guys
PS: If anybody needs a cluster here it's the contact info
Dustin Schneider
Schneiders Auto Wrecking
4779 Line 46
Rostock, Ontario
N0K 1T0
Canada
1-800-565-4606(Canada-Wide)
1-519-393-6169(Rest Of The World)
Discussion Starter · #14 ·
I don't care about the actual miles/kms. I installed it to see if everything works, now I installed back the original cluster on miles, and keep the Km's cluster for next year when I move to another country.
Discussion Starter · #15 ·
One more question for the guys that have a KM cluster..Do you guys have the shifter on the cluster ?????? This KMH's cluster that I got didn't came with the PRNDL..Just normal or I got a CE model, I don't know..
Thanks
Discussion Starter · #16 ·
Don't worry I found the difference my car it's automatic so it came with the shifter indicator, and the KMH cluster that I got It's from a manual. But since I have another MPH cluster, I'll take it apart and see if I can fusion them and make 1 KMH w/shifter..
I'll try to make a tutorial just in case somebody wants to take the whole cluster apart.
1 - 16 of 16 Posts
