1 - 9 of 9 Posts
Hello all,
I have toyota land cruiser 2010 and when i push the engine start/stop button it is not start i have to put my key fob on this button for a while then it will start
I also replaced the key battery still same and its for two days start showing the key light on the dashboard
any advice ?!!
Regards
Are you sure that you put the battery in correctly? Does it lock and unlock doors when used from 15 feet away?
What about the 12V battery in the vehicle, was is the voltage when the engine is shut off?
Thank you for the reply
When i replaced the battery it was fine for few days but after started again
I didnt get your second part could you please clarify
Regards
Aha what will happens if the key is near the car? That will be interesting to know
I can't say for your car or for Toyota specifically, but on some cars if the keyfob is too close to the car when parked, it is still communicating with the car and that is what runs down the keyfob battery. Note in the description of the Faraday bag I posted a link to, they specifically mention it can be used for keyfobs so that it blocks the signal to the car when not being used.
I can't tell you if this is your problem, or how far away the keyfob has to be when the car is parked. You should probably test the keyfob battery (or replace it again) to see if the keyfob battery is the problem.
Discussion Starter #8
Ok my friend thanks alot for the infos
The issue is its happens time to time some times is good for a week then it is doing this 3 times a day
Normally, I would say to try your other keyfob, but I guess a lot of people who bought their car used seem to only get one keyfob.
1 - 9 of 9 Posts
