hmmm now i wonder why my signature has that statement in it :naughty:
yeah i have also been thinking about this for a few months now but probably wont be able to do it until the summer or something. And of course ill have to go custom everything, i've already picked out my turbos, looked into manifold options, mapped out my exhaust, and looked at the piping issues inside the engine bay, which with the way i want to run it(one on each bank) will be the main problem. And im not going to run sequential which is i believe is the way that the Sportivo Concepts TT setup for the 1MZ runs.
Really the only issue i am confused about is that running one turbo at a certain psi (6-8) you are pushing a certain cfm of air into the engine, but with two at the same psi (one on each back running into a collector, using small turbos for quick spool) you would be pushing twice as much air. (Is this correct??) So really its not the psi that could possibly destroy the engine but the air flow, cfm?? So would i then need to run run a lesser psi (3-4) to compensate for this??
i would talk more but i have to close my computer lab, so ill cya tomorrow.
