1 - 9 of 9 Posts
permanent hiatus
the clear coat on the center caps on my rims is peeling and looking like crap. i want to remove the remaining clear coat so i can re-clear coat it. will paint thinner work, or is it too harsh?
i also repainted 2 of the caps black. that was a mistake. but yea, i put 2 coats of black and 2 coats of clear coat.
if i cant use paint thinner, what do u guys suggest?
thx
Grenaded piston
Paint thinner won't do anything.
You need to sand it off. Use some 400 grit or 600 grit sandpaper. 600 would be safer.
permanent hiatus
dammit. i was hoping i wouldnt have to sand. crap.
thanks
Resident asshole
Corolla
easiest way would be to bead blast them. Get access to a compressor, get the bead blasting handle and some blasting media.
permanent hiatus
Discussion Starter #6
what is this painter you are mentioning? how is that different from paint thinner?
i got a buddy with an air compressor. youre gonna have to give me more info about this bead blasting method, ive never heard about it before in my life.
thx again for the help guys
1 - 9 of 9 Posts
