1 - 5 of 5 Posts
Howdy 95 4runner with 210k 3.0 automatic 4x4
Just replaced headgasket and it has no spark now. Replaced the spark plugs, wires, rotor and cap.
Battery has 12.6v.
12v to ign coil with ign ON
Coil resistance is in spec on primary .4ohms
Efi relay working properly
Grounded on; pass side cam cover, 2 near accord compressor, 3 on drivers side lift hook.
Any ideas?
Thank you
Found a meter and ignition coil is good on primary and secondary.
I don't know. Camshaft sensor? I'll clean up grounds again
1998 T100 SR5 2WD
Welcome to the forums! :)
Have you confirmed that the ignitor is working? Give this video a view. ;)
I just got it running yesterday. Coil tested good. I added a 2gauge ground cable to block . My grounds looked fine but as a whim I added it and that got it sparking. Don't dismiss the grounding wires if you don't got any spark.
1 - 5 of 5 Posts
