1 - 12 of 12 Posts
2007 Camry LE
This is my 2003 Camry I4. I got it back in 2008 with 65k miles. It's my daily driver and it's coming up on 170k miles. Car gets good fuel economy and has been super reliable.
Lighting:
Low: Morimoto bi-xenon FX-R 1.0 with Osram 66240 CBI, powered by Morimoto XB35 ballasts.
High: Philips HIR 9011.
Suspensions:
TRD rear sway bar with welded reinforced brackets.
Front TRD strut brace.
BC BR coilover 10/8K with Swift spring.
SPC camber bolts.
Wheels:
Enkei RPF1 17x7.5 on General Altimax RT43 215/55/17.
H&R 10mm hubcentric spacer.
ARP Lexus IS300 wheel studs.
Brake:
Front upgraded from 275mm to 296mm rotors with powder coated "TRD" Lexus LS430 monoblock 4 pots aluminum calipers.
Exteriors:
Gen 5.5 Camry SE gold front grille.
SE headlights.
Gen 5.5 SE tail lights.
Replica of Vizage front lip.
OEM rear ground effects.
Valor exhaust tip.
OEM mud guards.
Emblems debagged.
Gutter guard mod on front grille.
Plasti Dipped rear Toyota emblem.
Rare 'SET" Toyota trunk lip spoiler.
AVS in-channel visors.
Fenders rolled.
3M 1080 Gloss black roof vinyl wrapped.
Llumar CTX 50% ceramic tint on all windows except the front windshield.
LED license plate lighting.
Interiors:
Gen 5.5 Optitron gauge with red accent overlay and Solara's odometer LCD.
All interior lighting swapped to LED.
Red LED ignition switch ring.
Gen 5.5 center console swapped.
OEM sport aluminum pedals.
OEM all weather mats.
Super Moderator
2005 Corolla CE
Very nice, but why Honda center caps on the wheels?
2007 Camry LE
Enkei caps are very expensive and the Toyota caps' diameter are smaller so they won't fit. I plan to paint over the caps when time permits.
2007 Camry LE
Not direct bolt on. Aluminum brackets were needed and also the calipers had to be machined as well.
2007 Camry LE
Discussion Starter #7
Brackets were custom machined. Costs for parts and labor were somewhere close to a grand.
Leviathan
Nicely done! those calipers are screaming for bigger wheels! So jealous of the SET spoiler.
I think you should add some fogs to complete the front.
Planning on tinting the windows?
2007 Camry LE
Discussion Starter #9
Windows are tinted with Llumar ceramic 50%. The darker tint is nice but I can't really back out at night.
I had 18'' wheels before but the empty gap between the wheel and rotor doesn't look good. Also, there's a silver painted SET trunk spoiler on EBay at the moment.
Reactions: VindiCated
2003 Toyota Camry LE 5 Speed
Woah I'm late, but holy smokes dude, you've built my dream Camry! The wheels, taillights, everything! I hope I can make my Camry look as good as yours!
Edit: I just saw the rear lip spoiler :( Dude this is such a beautiful build
2007 Camry LE
Discussion Starter #12
Thanks man. I sold the Camry last year. The spoiler, front, side and rear valances give the Camry a unique look compared to the sea of other Camry. I was able to sourced most of the valances except for the side skirts.
The wheels and brakes setup live on in my current 07 Camry.
1 - 12 of 12 Posts
