6 inch pro comp, 35 inch tires (may change my mind and go 33 or 285/75)...its going to have a pretty big impact..hahaamp2oo1 said:I wouldnt think the lift would change the milage at all. How big of a tire are you going to be switching to?
ohh yeah, i have the bestop softop. i have checked with that on my truck and off, its seems to be a little better with it on, but still averaging round 15 mpg.lightningxb12 said:A bed cover or topper would help.
but the lift itself should have no affectbarlowrs said:6 inch pro comp, 35 inch tires (may change my mind and go 33 or 285/75)...its going to have a pretty big impact..haha
well, thats where im unsure, my truck was the one pro comp used for development of the lift, so i get it all free, but in the development they relized that 35" do rub a little, and since i go offroad often, i cant flex that much. I'm going with the x terrain tires, and the 285/75 actually have a bigger diameter (33.1) than the 33x12.5 (32.7)..the 285 are just a bit skinnier, which is fine with me. im sure the 35" would look better, but for functionality, i think the 285 would be betteramp2oo1 said:but the lift itself should have no affect![]()
Id go 34/35 with the 6 inch, 285s may look a little lost in the wheel well with that much lift. Sounds like its going to be a pretty sweet setup... Ill be looking forward to the pictures![]()
No I understand the lift and tires are going to kill my milege. the tires being larger and heavier obviously, but also the aerodymaics of the raised truck (I'm an aerospace engineer) will effect it also, i just want to make sure nothing is wrong with the base truck before I start working on it. I know the milege is going to go down, but I'd rather start from a normalized milege than one already lower than it should be.gahunter said:I don't understand it. People want better gas mileage but then say they are going to lift the truck and probably install bigger tires as well. I also don't understand one comment saying the lift shouldn't effect mileage. How do you explain that?Oh well good luck and if you figure out how to lift the truck which will increase wind drag and add bigger rims and tires increasing the weight and still have the same mileage, let me know. Let the whole world of autoracing know too.
If you read his post you would see he doesnt really care about his MPG he just wants to make sure theres nothing wrong with his truck.gahunter said:I don't understand it. People want better gas mileage but then say they are going to lift the truck and probably install bigger tires as well. I also don't understand one comment saying the lift shouldn't effect mileage. How do you explain that?Oh well good luck and if you figure out how to lift the truck which will increase wind drag and add bigger rims and tires increasing the weight and still have the same mileage, let me know. Let the whole world of autoracing know too.
Anybody see the Myth Busters Episode where the compare trucks with the tail gate up and down and their gas mileage? Do you think that putting on a bed cover would kinda be keeping the tailgate down?lightningxb12 said:A bed cover or topper would help.
