1 - 5 of 5 Posts
Vin and stickers say it is a 1.6 4a-Fe BUT like the title says the motor has been swapped. I need to know how to identify it. I don't have any info on what type of motor besides the plate on the valves that say "16 valve efi"
What other markings or stamps are on these motors so I can figure out if its the 4a or 7a
Full Throttle
1993 Corolla SE Ltd
The best way to check which engine you have is to look at the engine code that's etched into the block. It's located to the right of the exhaust manifold and is stamped vertically.
Here's some photos of it's location:
It will says 4A for the 4A-FE or 7A for the 7A-FE (above says 5A because it's a 5A-FE). You will have to get down low to see the numbers on the block and may have to give it a bit of a wipe to get rid of any dirt etc, but this is the most reliable way of checking which engine your car has.
1 - 5 of 5 Posts
