1 - 6 of 6 Posts
93 camry 2.2l with idle problems. Son in law replaced a couple of sensors and it idled at around 2500 rpm. Replaced them with the originals and it is now idling around 1200. Any ideas?
replace throttle position sensor and idle control valve. I got the vehicle after he replaced them. It was idling high when I got it. As far as I know they are the only two. Replaced the original after cleaning the idle control valve and it runs fine, but idles too high.
Toyotas.
Read the above. Also check for vacuum leaks and cable interference.
1 - 6 of 6 Posts
