I need your advice! I have an 88 Toyota Pickup, 22RE, M/T. The idle is too high when I come to a stop. Sometimes a blip of the throttle will bring it down a bit, but not enough. The throttle cable works smoothly, and the throttle valve itself moves well and is not sloppy. If I rotate the throttle valve counterclockwise when idling (to fully closed position) it brings the idle down to normal (it only moves about one milimeter).
At first I thought it might be the Dashpot (DP) diaphram, but when I push the plunger down (away from the throttle valve stop) the idle stays too high. Could it be the Auxilary Air Valve Assembly (P/N 22230-35010)? It is an expensive part, so I want to have a good idea it is the problem before replacing.
